Most accurate way to do an eplan part list synchronisation
I need to do an explain part list synchronization with utmost accuracy.
Kindly recommend the best website that can show me how to transfer and update XML file with large volume data through script.
Best Answer by Spreckelmeyer Kayla
Answered By 0 points N/A #131494
Hi Desireenataliaa,
I think you can easily rely on ShareFile. I personally used it and got a good result. It’s a Critix Systems, Inc. product. You can easily send, and access files and folders by ShareFile. It is very user friendly.
Follow the link below:
It’d be better if you try the trial version first. Then take your decision.
Good Day.
Answered By 50 points N/A #131495
Hello, Desireenataliaa
Hope you are fine. Don't worry , hope your problem can be solved. Ability to transfer XML is now a burning issue.
If you see the tutorial with example, you will understand better.
Here is a website that will help you to learn it.
See the tutorial
Hope you will get your answer.
