I am looking for the most consistent program that I can use to backup my Windows PC. I tried different backup programs before but it always failed. I searched on the Internet and there are so many choices. I want to know which is the most consistent. Thanks.
Most Consistent Program to Backup Windows
I am writing the names of 10 best backup and recovery applications below.
AOMEI Backupper
EaseUS Todo Backup Free
Redo Backup and Recovery
Cobian Backup
Macrium Reflect Free
DriveImage XML
Backup Maker
Paragon Backup & Recovery 2013 Free
CloneZilla
Duplicati
You can use any one from these.
    There are many programs but it completely depends upon individual needs. Some of the best free backup softwares are: 2brightSparks, Syncback and Microsoft’s Synctoy. I would say try all of them.
2brightSparks: This software can create a Zip file backup and synchronize files across multiple systems. The GUI is easy to use and encryption (256-bit AES encryption) is top notch.
Syncback: It allows users to schedule specific backups on different files and folders. It does not use much PC resources. Backup can be easily exported to logs in HTML for easy readability.
Some other reliable programs are: GFIBackup, Cobian Backup, FBackup, EASEUS Todo Backup and Comodo Backup
