Most ideal approach to breaking down the appeal sent over SSL
90 points
Posted on - 05/29/2015
What is the most ideal approach to breaking down the appeal sent over SSL by portable application? It is redundant that the correspondence convention is Http/s so catching them with Burp/Zap/Fiddler or whatever other Http intermediary won't basically work, however by what means would we be able to get the movement to try and achieve the intermediary?
