stefenhon
20 points
Posted on - 08/17/2011
I am using Nokia 2730 Classic mobile and in order to get huge application and make my mobile affluent with software I generally download from https://www.getjar.com/ , https://www.zedge.net/ , https://www.mobile9.com/ etc.
A month earlier, it worked well but at present I have downloaded many applications including NTH file, facebook chat application, s40 Reader etc. but at this time when I opened it, it tells, "Unable to open" or "You don't have any internet connection" but I have an internet connection and it remains connected always and most of the time I browse with my Opera Mini software.
Can you tell me how I can be free from this problem?
Gonzales
Most of mobile application is not working
Dear,
Mostly in Nokia mobile this problem is commonly occur. No need to worry it can be resolved and there are suggestions for this. First you will have to check your mobile software and its data. It should not have any virus activity because so many times if a virus is stuck on your mobile and if you are using the memory card in your mobile just remove your memory card and then try to use the internet. This might work, other wise install an Antivirus program in your mobile and try to scan your mobile completely. Sometimes your mobile settings can be disturbed due to some software changes. Just try to restore your mobile settings and then restart your mobile. Your mobile will be restored to its original settings and it will work.
Trevor
Your problem might be a virus infection or corrupted applications. Most of your installation in our mobile devices is located on our memory card. We cannot depend on the integrity of our flash memory, more often the memory got corrupted in no possible reason.
Try reformatting your memory card and reinstallation of your mobile software might be the solution.
If possible virus infection is suspected, you may reformat your cell phone firmware, maybe using spider format (just search on the Google how to do the spider format) or perform a Restore on default then format your memory card and reinstall everything.
kelvs
I had a Nokia Series 40 phone before and I also experienced this kind of problem. Series 40 OS, especially with Nokia, is a highly restricted system and that's why it can't be infected with viruses by any means. And it can only run .jad and .jar applications.
I was also fond of downloading and installing themes and java applications from those websites. So here's what I actually did to solve that problem.
First, go to Menu>>>> Settings>>>> Restore Factory Settings>>>> Restore Settings Only
It might require you to enter your security code, so just make sure you still remember it. There are two options to choose from.
You’ll be allowed to reset all preference settings through Restore Settings Only without having deletion of any personal data.
To restore all preference settings and delete your personal data you can use Restore All. You’ll get your contacts, messages, media files or activation keys etc.
