anonymous
7060 points
Posted on - 08/09/2011
I clean my CPU for dust. i unplug every cable for this CPU. when i open my processor fan then i broke one clip of processor now i plug every cable and processor fan.
When i open my computer then it cannot open desktop.
So what is problem?
LoisP
Motherboard and Processors cannot run my computer.
Kindly double check if you properly connect all power connectors to the motherboard.
Please see below the list you need to check:
1. CPU power supply
It is a 20 or 24 pins power connector, you must connect it to the motherboard.
2. Processor
You must check if the processor is properly seated and connect to the motherboard the CPU fan power connector.
3. CD/DVD Drive
You must connect IDE/SATA data cable and power cable to the device.
4. Hard Disk Drive
5. Power button, Reset button, and USB
You must connect the power connector to the motherboard, kindly see the label on the motherboard for the specific buttons.
After doing all this procedures, you may turn on your computer. Please take note that if you will conduct preventive maintenance to your computer, you must put labels on the connectors so that it will be your guide to put connectors
in their proper place.
LoisP
I'm not sure which pin are you pertaining to so I can't advice if you can purchase a spare pin. Maybe this broken pin is the reason why you are unable to open your computer. It is best to bring your PC to a technician. They can surely replace that broken pin and can make your computer work again. And also, do not try to clean your CPU with anything like a brush or a cloth. Chances are, you will broke all the small pins connected on the motherboard. You can use an All Purpose Air Duster instead wherein you only need to spray it on the CPU to make it clean.
