jdaniels
10 points
Posted on - 03/15/2012
I have laptop in On condition but the motherboard doesn't appear on monitor screen.
– LED Power is On
– No beep
– Keyboard lamp is normal
-I have changed the power supply, RAM, VGA, processor, battery cmos and clear cmos but nothing changed.
Please, solve my problem.
Motherboard didn’t show up – ASUS P5KPL-AM EPU
Hey Jdaniels!
The problem you are facing is same as mine. I have Acer 3200+ computer system. One week ago my system did not display any result on the monitor screen. I was not sure about the problem. I checked VGA, RAM, Cables, and everything.
Everything was fine but still my monitor did not show any display. I contact the computer mechanic to ask what the problem is? He told me that my BIOS is not working properly. So he updated my BIOS and since then my computer is working properly.
I am sure; same is the case with you. Check your BIOS and update it, if necessary. Your computer will show the display
Thanks
