Hello
I got this error.
Unable to process the request
I'm receiving this on a site "Unable to process the request", when 80% of my works are finished. I am not able to see details!!!!
As well on not many ones that load I am not able to make out the route, just this occurs from my computer as well as any other computer i have attempted with any other browser like IE, Chrome, and Firefox, BTW it all runs very well from the phone.
I need a solution. Thanks a lot.
Motorola MotoActv – Unable to process the request
If the program runs smoothly on your mobile phone then maybe the version you have on your computer is not compatible with your operating system. Check first the program’s system requirements so you can verify if it is a compatibility issue or not. You should also check if your computer has an active internet connection. Or maybe if you are using it during peak hours, try it again after a couple of hours or better yet during off-peak hours so you can be sure to have a good connection.
You may also try doing a clean installation of the program just to fix any corrupted files that might be affecting the application. Uninstall the program then restart your machine. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install the program back then check if you are now able to use it.
