Motorola V180 voice mails convert to Cingular carrier mp3 format
How can I convert the saved voice mails from Motorola V180 phone to mp3 format? I am using Singular carrier. Please suggest a solution.
Hi Joanna,
First is to save your Voice Mail file to your Computer. To do this just record your own messages by getting a 3.5 mm cable extension. Then put a 2.5mm adapter on it which plugged into your Motorola V180 phone headset connection. Connect to your computer then called your Voice Mail. But you need to have Audacity. In case you don’t have this Application you can get it here > https://audacity.en.softonic.com
For tutorial for Audacity just read this link https://sourceforge.net/projects/audacity/?s=install
Now after installing the Audacity Open it and Hit Record in the message in your voice mail. It will automatically convert your Phone Audio Files to mp3.
Hope this Help.
A.Wright
