I have the new 27" iMac with Quad Core i5 3.2 GHz, 8 GB memory, 1 TB HDD and OSx Mountain Lion. My dilemma is, I never had problems running Fortran in OSx Snow Leopard and I can't run Mountain Lion Fortran codes based on DFFT. Any solutions on my problem?
Mountain lion fortran codes not running
Hello
To run Fortran on Mountain Lion you have to install Fortran compiler. I found good tutorial for this but since it's too long I won't post it here I'll https://sites.google.com/site/dwhipp/tutorials/mac_compilers just give a link
Basically, you need to download a compiler extract it and then install using Terminal. All commands are listed in this tutorial so you won't have any problems. Regards.
