Mouse Cursor is not responding in MS-Outlook 2007
Hi Jasika,
 I understand your problem as I can see when you work with the text field cursor does not respond. So, I have a few solutions for you.
1- Check your cursor properties from your OS's control panel.
2- Try to reset your computer settings to default mode.
3- If still problem persist's then simply try to reinstall the application.
-Edward.
Hi Jasika,Â
Yes, I know, this has been an ongoing issue with Microsoft Outlook 2007. But the good news is that I was able to solve this problem in my Windows 7. What I did is just to allow the Microsoft Outlook application to run as Administrator from the compatibility mode in the application's properties. I was able to switch it from the Run As Administrator mode and got the fix to this issue. Try this same fix as I have gotten and I hope this works for you too.Â
Best of luck Jasika.
