Hi to everyone,
About the compatibility of driver mouse multi gesture. I am using windows 7 starter 32 bit operating system in my dell computer desktop and I think this has to do with the compatibility issue in my driver of mouse multi gesture software. We have to install drivers before we can a specific application. I need some advice.
Your suggestion is very much welcome.
Mouse Multi-Gesture Software not compatible with Windows 7
Certain multi gesture mouse has compatibility issues with windows 7 operating system. Don’t worry; I’ll help you with some basic troubleshooting steps.
>> Right click ‘my computer’ and select ‘properties’.
>> Click on the ‘device manager’ icon which is located at the left hand sand.
>> On the menu you can see ‘mice and other pointing devices’.
>> Double click that icon and it will list the device.
>> Right click and select ‘properties’.
>> Select ‘driver’ and then select ‘update driver’.
>> The computer will search for the latest driver for your mice and install it if you have an internet connection on that computer.
Thanks and regards
