Move libraries base folders to other location than default
Hello experts,
My problem started after my last Windows Update. Also, there are times that I can't seem to log in or after logging in, my libraries and the default system was damaged and the report stated that my library is not available. Is it okay to move the base folders and the library settings to other location aside from its default location? And the User profiles and AppData folders as well.
