Movie Maker Error Code 0x887a0005 Bug Fixing
I was trying to take a video of my photos, this error is displayed – movie maker error code 0x887a0005. Can you help me resolve this?
Hello, I’m trying to make a video from some of my photos and I have the same problem. The message is “There are no usable files in your Movie Maker project that prevent you from saving your movie, please check if file preparation is enabled in the options, or delete the files and try again.”
I tried it with and without the file preparation option, with the same result. If I choose a 1080p preset, the error will occur at about 35% of the encoding and if I try to reduce the resolution I can encode almost 50% of my video. , Once the error has occurred, some of my images are marked with a warning icon and I can “fix” them but the images are valid and this is not always the case. the same ones that are “invalid” when I try to reload the project and start encoding. I hope this will help fix this annoying mistake.
