Moving files from One Note 2007 to Google Docs
Is it possible to move all files/ records from One Note 2007 to Google Docs?
Is it easy to do?
It would be great if you can give me a step-by-step instruction.
Thank you.
Is it easy to do?
Thank you.
Hi
Yes there have a way to move all files or records from On Note 2007 to Google Docs. Microsoft added this type of feature in their MS One Note 2007 application.
Here following the steps to do that:
At first create your files in MS One Note 2007.
After complete the create of this file then select the option and then select Export to Google Docs & Spreadsheets
 I already shared the process to regarding your issues. That’s a simple process.
So if you follow the above steps then you will able to complete your task or project.
Thanks
