Moving OWA files to some other IP in the same server
Hi, I just want to move up my OWA files to some other IP in the same server in the Exchange 03. It is on the W2K3 server. I need to build up another website on this existing server that must have the different IP. Is there any solution to accomplish this task?
Answered By 55 points N/A #104846
What are you basically trying to achieve here? If your goal is to achieve higher performance, then you can install CAS and move your OWA there. But there is a traditional way that you must get a second server in order to achieve that.
If you have no performance issues and you just want to make a second server or if you have security measures to do for safeguarding data then you can try adding CAS in DMZ to put the exchange behind a firewall.
But it is a very hefty process, you have to use a virtual machine in order to achieve this task. But I would advise you to get a dedicated server with lots of VPS and use it for this purpose.
