Jahji
Posted on - 12/06/2011
Hi Everyone,
I have an old Applian FLV player which is been completely uninstalled during a downgrade of Vista to Windows XP.
I tried to use Moyea FLV player in XP that suddenly can start because an entry point not found.
Where could I download this entry point to run this Moyea application?
I tried reinstalling the Moyea player but it doesn’t solve.
Any help please,
Thanks!
Moyea FLV Player.exe – Entry Point Not Found
The procedure entry point_except_handler4_common could not be located in the dynamic link library msvcrt.dll.
OK
Moyea FLV player entry Point Not Found
As far I know about entry points, they are mostly caused by system files that have not been configured properly, and they normally come about when the registry system of the computer has been overloaded with a lot of data.
The problem may also occur as a result of some important system files that are used by the flv player being broken or they could be missing.
But the good thing is that you can fix the entry point problems.
All you need to do is get a tool that is used for repairing registry errors and run it on your computer. I will recommend that you download a registry repair tool called WiseFixer, install it on your computer and use it to fix the problems. You can get here.
Regards
Thompson Locker
