John Pike
70 points
Posted on - 10/28/2012
Hello all,
I am using PowerPoint 2010, and I installed moyea PPT to convert a PowerPoint file into a video.
In trying to do so, I was met with an error on the screen. The screenshot of the error is attached below:
He message states:
Moyea PPT to video converter
Exception occurred while importing the PowerPoint file: F:sharetest_PPTaustralian_birds[3m12s].ppt
ERROR: [EOleExceptionj: Unspecified error.
OK
Any idea why this is happening? Your suggestions are most welcome.
Thanking you loads
Regards
Moyea PPT to video converter error
In most cases, the problem has nothing to do with your Moyea software and the PowerPoint file. The culprit in this case is VBA, or Visual Basic for Application, which is a component that needs to be installed within your MS Office suite. To do this, run the MS Office installer, then look for VBA, which is under the Office Shared Features. Make sure to add this component into your existing MS Office. You can then try the conversion process again.
I think you are having problems cause of the missing update. Your software is working fine as well as there is not fault in .PPT file you have. You need to upgrade your version of Microsoft Office or reinstall it and download the visual basic applications file. I think reinstalling is better option and while reinstalling unfold the office shared features and choose 'run from my computer' by right clicking the visual basic for applications.
Hope this helps
