Green Scott
50 points
Posted on - 10/06/2012
I decided to download and install Firefox v3 last time. It had a system tray icon resembling the download file icon. When I tried to initiate the program I am prompted to reboot; however, I have had to reboot several times, even running Firefox as an administrator.
I got tired and tried to remove it instead, but was also asked to reboot.
The Firefox forums haven’t been helpful, so please help me on this.
I would be really grateful.
Mozilla Firefox Setup
Your computer must be restarted to complete a previous upgrade of Firefox. Do you want to reboot now?
Yes No
Mozilla Firefox Setup – Error
Hi, Green Scott,
As you know, from Google you can find a lot of forums but the chance of getting the right solution depends on where you post your problems. We have so many different forums to get overcome from error in installation of Mozilla.
So classifying and posting them on relevant forums is the best way to get your answer step by step.
I can suggest that you download the Mozilla software from this website and try to install it before uninstall your previous version of Mozilla and you not find any kind of errors.
https://filehippo.com/download_firefox/
Hi.
Green Scott.
Your Firefox software doesn't install properly because there is some unwanted exe file. You have to download fresh software.
You can download this software from https://filehippo.com/ (free).
Best regards,
Brandy Gilmore
