katrinakaif
Posted on - 08/12/2011
I use Mozilla Firefox. It is so good operating system software but sometimes it makes uneasy to me. It's shown me update of Mozilla Firefox. But I think my system always updates automatically after then it shows me it.
Thanks katrinakaif
Mozilla Firefox show me update
To solve your problem you have to disable your update settings on your browser settings. Open your Mozilla Firefox and then go to the "Tools" menu and then click the "options". This will open a window where your settings can be adjusted as to your choice.
Now go to the advanced tab in the same window. There you'll see options such as – Firefox, add-ons, and search engines. If it is marked, then unmark all the 3 items. Then below click to "ask me what I want to do". Click apply and then OK. Now your settings have been changed. Restart your Firefox and you can work out.
Trevor
Mozilla Firefox is not included in your system updates. Mozilla Firefox has its own updater system. It’s good to update your browser to its latest features. This will give more functionality with your browser.
By the way, you can disable the automatic update in Mozilla Firefox. Suing the following steps will help you to disable the update options in Mozilla Firefox.
1. Click Tools, and then select options or just press ALT + T, O.
2. Click the Advanced Option.
3. Click Update tab
4. Uncheck all three options in automatically check for updates: Firefox, Add-ons and Search Engines.
5. Then click Ok.
Solution
Hello katrinakaif
I read your problem. But I Think this is not a very critical problem. Now I try to give some workable solution for your problem. Please read the below solution and work step by step then I think you will cover up the problem.
To get rid of these problems just follow the below step:
· First go to tools tab
· Then go to option
· Then go to the advanced tab
· Then select update tab
· Then mark “Automatically update and install the update
· Then press ok
By doing this Mozilla Fire fox will automatically update and don’t ask you to update.
Hope it will help you.
Thanks from
Arfat hossain
