Mozilla Firefox video initializing problem
I have used the Mozilla Firefox 5.01 but when I tried to open a video file from screenshot.com it can't initialized the video? What's the problem and how can I recover it?
First you have to check that the plugin of Firefox which supports the video running and buffering in the browser is installed or not. if installed then try to update it from its real source and then restart your browser by closing it and then reopen it and try again otherwise check that which windows you are using. Is it registered or not? Try to update the previous or the best thing is that uninstall it and download the new and latest version from a good source and make sure that your system supports the latest version. Other thing is that there might be some file corrupt or some virus is there which is resisting the running of your program so try to scan your computer and repair the windows and other files. Do this in normal mode or the best thing is to do it from safe mode.
You need to check that your browser is up to date more over you can check that there is no fault in your browser and it is working properly. There is no virus in your computer and your computer is virus and spam free. Also make sure that you have installed a full version of flash play if you are trying to run a flash video. Also you can check the settings for your browser and make them default settings as they will help you to set them to default values and it will work fine.
If you are using two browsers at a time then check that what is your default browser and set that browser to default which you use most of time. Try to reset the internet settings and delete all the browser history to make your videos work fine.
Notifications
