Crewe Bob
30 points
Posted on - 12/22/2013
Hi there,
I have A Samsung Galaxy Note 10.1 2014 which am trying to use to play mp3 files from Drop Box but the progress bar loads until a timeout error comes up, what could be the problem? Does DropBox stream music directly? How do I get these files playing?
points
Mp3 Files not playing from Drop Box
It is hard to play music directly from Dropbox especially on Android. But we’re fortunate that there are apps to help us in this situation.
Dropbox Music Provider is such an app. It helps playing music from Dropbox with JustPlayer so first of all, install JustPlay from here.
Also, you can use Dropbox Android App. This will allow you to play your music from Dropbox using the built-in media codecs from your Galaxy Note.
