Hello and good day and TechyV friends and pals!
I have mp4 file that needs to be converted to be played on RealPlayer. Here are my sets of questions, can mp4 converter encode in real player? Is RealPlayer having a converter? What file formats are available for conversion? Is it compatible on any mobile handsets and tablets? Any help would be appreciated.
Thanks and good day.
Patricial Ferro
MP4 converter encode in real player?
Hello Patricial,
I hope this can help you, now here we go. You can download any format you want in your MP4 to convert in a real player Through Total Video Converter you may able to download it here.
It's not just for video but also for music, phones, and making a music for videos with different file format. The overall design and features of this program is very easy to navigate and use. It is a trial version for 30 days and if you don’t like to have it trial you can purchase the full. I’ve been using this since then in converting and it's not hard to use.
1. Download the Total Video Converter through the link which I give you.
2. After downloading click to run the program and wait until the program is done installing.
3. After installing you can see like this on your screen. Drag your MP4 file in the center of this box.
4. You can see here the format you want to have.
There are many formats that you can convert to and you can choose any of that. I hope this helps you a lot.
