goddfrey
20 points
Posted on - 08/15/2011
I have MP5 Sony Player with 2GB Memory Card. I wanted to save my data into my PC. Windows Xp is installed in my computer. When i attached Sony Player with computer, the Windows XP detected it and in “my computer” Memory Card was showed by XP, but when i checked memory card in “my computer” the memory card was empty. What’s the reason?
LaraP
MP5 Sony Player not connecting with PC
Hi Goddfrey,
There are things to consider why you cannot see your files even you can access your memory card.
Please see the details below:
1. Virus infection – It may be the cause of a virus or malware why your files is missing.
2. Corrupted files – It may be the cause of a virus or malware why your files is missing,
3. Memory card – It may be your memory card is defective.
4. Hidden files – It may be the files in your memory card was set into hidden files.
Please follow this procedures to disable hidden files:
You must click start menu
select My Computer
select TOOLS TAB
click Folder Options
click VIEW TAB then select SHOW hidden files.
Now, check your files on My Computer then right click the folder and on General tab, uncheck hidden then apply button followed by OK button.
LaraP
