shawnj cruz
Posted on - 02/07/2013
Hi and good day!
I have MPG files to play. It seems that my Windows Media Player doesn’t play MPG and MPEG Files. What is the most download mpg file player use in windows or even Mac? Is there I need to do with my Windows media player to play MPG files?
Shawnj Cruz
Mpg file player available for download?
1.   Visit web site with downloadable K-Lite CODEC.
2.   Click on the K-Lite Codec to start download.
3.   Open the installation file to start putting in the K-Lite CODEC. Click "next" through every screen of the installation till K-Lite installs on your PC. You will see a seemed icon right on your system tray within the bottom right corner of Windows when you exit out of the installation. This means K-lite CODEC is passive and runs within the background.
4.   Attempt opening a video you could not open along with your video player before, like VCD or MOV, and K-lite ought to be able to open it.
