Mplab v6.60 in Windows server 2003
Does mplab Windows Server 2003 supported by current OS or other development tools? I always imagined this as a big problem for me because every time I start the computer, the windows 2003 will report an error especially when I start the mplab v6.60. Is there something I have to do to solve this problem? Just let me know if mplab will work under windows 2003 server if I will download any upgraded software ( if there’s any) or will I change the settings? And how am I going to do this? I would like to upgrade my development system and I am much curious if anybody has the same issues and how it was solved. Thanking you all very much for any solution you will share with me.
