Hi there,
I have a ton of eml file that I need to view and edit when needed. We are currently receiving around 30-40 eml files a day and the only dbms that our company provides is the one that came with the MS Office suite which is MS Access.
So I am asking you, is there any ms access eml plugin to view and edit eml files without needing to install additional softwares? .
Thank you.
Ms access eml file viewing
Hi Marc A White,
Actually I have not use this .eml files. But in my experience I have try to answer it. Follow the steps:
1. Select the .eml file and click the right button of the mouse and then click “open with”->Choose default program
2. Then you will see a window. Select “Others programs”-> from the list select MS Access
3. Then click to “Always use the selected program to open this kind of file”
I don’t sure it works or not.
