Ms access export oracle, need help with this one
Hi guys. I am creating a database application using vb6. I need your help on this, I am using ms access as database. How can ms access export oracle database? Thanks in advance guys.
You should use programs to convert from Ms Excel to oracle database:
The 1-First program is Excel Oracle Import, Export & Convert Software that Use MS Excel as a front-end interface to an Oracle database. Use Excel to import and export tables to and from an Oracle database. Read and write tables to and from Excel without SQL knowledge. Excel 2000 or higher required.
To download it:http://excel-oracle-import-export-convert-softw.software.informer.com/download/
2-second program is OraLoader: With OraLoader, you will finally have the power to move data smoothly. OraLoader is a data conversion tool that helps DBA and database developers import/export Oracle databases to or from flat files and Excel files. Features: Import from both flat files and Excel files. Export to multiple formats (text, csv, excel, html, xml, SQL*Loader control file).
To download it : http://oraloader.software.informer.com/download/
Then you should take the file you converted to Vb6 and import it.
Hello Eleni,
By using VB6, to make a database application not an easy one i must say. You just have to go through some process to your goal. In MS Access, make a "Marco" to dump the data from a table then make sure a task scheduler is running and put the marco in it.
Start > Program > Mircosoft > Access > Open existing database > Marcos > new
Hope, it's helpful for you.
Regards.
Notifications
