Hey guys,
While I am using Microsoft Access when I have it maximized, how do I when using ms access open application from within? What is the code or program I can use to achieve this? Preferably something simple as I'm not very tech savy.
Thank you in advance everyone.
Ms access open application with access window already maximised?
In MS access when you open a form it appear top of the screen and hides all your backend forms/tables etc. To fix the problem you have to set the form properties so that it appears inside MS access.
Adopt the following method:
Open form in design mode
Click on property sheet and make sure the following things(as shown in the snap shot)
Change the property of form as you want
Under the Formatting Tab you can also set the following properties if necessary to you.
Auto resizes, Width, auto center, Min and Max button, moveable etc.
Note: Your question is not so clear. If you have need of further guideline do write us.
