Ms access run query dos how to’s
I am trying to figure out how to use Ms access run query dos. Please tell me how to execute a query in Access via dos. Is it possible to call Access with command lines?
Microsoft Access not supports DOS or CMD. Because if you are utilizing DOS then you use windows 3.11 it contains its on office, and if you want database in DOS then use old version of Dbase or FOXPRO for DOS. MS Access 97 made for Windows 95 and 98.
Recent version of MS Access 2010 using in Windows 7 or 8. So Access cannot be controlled through Any CMD Command only some macros you can make for process and batch processing created for special tasks. So MS Access can use DOS but you Not Use MS Access form DOS.
