MS Access Service Pack Installation Error
I am using MS Access 2003 running under Microsoft Windows XP with Service Pack 2. I encountered a problem when I opened a database. It prompted me to have a copy of Jet 4 with Service Pack 8 installed on my computer.
When on the process of installing Jet 4, I came across an error of KB829558 Setup Error, and it suggested that there is no need for me to install a Service Pack since the service pack I am trying to install is older version than what I already have.
Setup has detected that the Service Pack version of this system is newer than the update you are applying.
There is no need to install this update.
I am wondering why the system at first suggested me to install a Service Pack while I have a newer Service Pack installed. It's quite tricky for me to understand.
If somebody has tried solving this issue,
Please do share some points.
