annie brown
20 points
Posted on - 05/22/2012
I installed GP 2010 R2 on my computer and started off with deploying SSRS and Excel Reports.
I am using SQL Server 2008 which SRS deployment doesn’t recognize. Below is the error message that I am getting:
Error:
Microsoft Dynamics GP
You do not have security access to the location where you want the reports to be displayed.
MS Dynamics GP Error Message regarding Deployment of SRS
You should check the configuration again of your Microsoft Dynamics GP 2010 R2. It’s possible that your program is not configured properly to deploy different reports on different locations. You should check the application’s settings again.
If there seems to be no problem with the application’s settings, try uninstalling it then check your computer for any possible errors. Use a disk utility application to check the system. Then after the check, install Microsoft Dynamics GP 2010 R2 again. After reinstalling it, configure it again then do a test deployment of your reports and then see the result. If the destination of your reports is to another computer over the network, you should check your user rights on that machine if you are allowed to access its drives or copy some files to it.
