MS Excel Error in CGI
Hello TechyV buddies!
I am having some issue on MS Excel. I am suing MS Excel’s data analysis tool to deal with some data on excel. Because of this I have used the following:
$excel->AddIns->Add( "$xll_path" );
$excel->RegisterXLL( 'Analys32.xll' );
However, when I try to do this: 'C:UsersLF>perl test_1.pl' And error appears when I try to open CGI via IE. ERROR INFO:
[Mon Jun 04 22:32:02 2012] [error] [client 127.0.0.1] in METHOD/PROPERTYGET "SaveAs" at C:/Program Files/Apache Software Foundation/Apache2.2/cgi-bin/qynjjjyjpjhsgj.cgi line 1372, referer: https://www.techyv.com/cgi-bin/qynjjjyjpjhsgj.cgi [Mon Jun 04 22:33:59 2012] [error] [client 127.0.0.1] Premature end of script headers: qynjjjyjpjhsgj.cgi, referer: https://www.techyv.com/cgi-bin/qynjjjyjpjhsgj.cgi [Mon Jun 04 22:33:59 2012] [error] [client 127.0.0.1] OLE exception from "Microsoft Office Excel":, referer: https://www.techyv.com/cgi-bin/qynjjjyjpjhsgj.cgi [Mon Jun 04 22:33:59 2012] [error] [client 127.0.0.1] , referer: https://www.techyv.com/cgi-bin/qynjjjyjpjhsgj.cgi [Mon Jun 04 22:33:59 2012] [error] [client 127.0.0.1] xb2xbbxc4xdcxc8xa1xb5xc3xc0xe0 AddIns xb5xc4 Add xcaxf4xd0xd4, referer: https://www.techyv.com/cgi-bin/qynjjjyjpjhsgj.cgi [Mon Jun 04 22:33:59 2012] [error] [client 127.0.0.1] , referer: https://www.techyv.com/cgi-bin/qynjjjyjpjhsgj.cgi [Mon Jun 04 22:33:59 2012] [error] [client 127.0.0.1] Win32::OLE(0.1709) error 0x800a03ec, referer: https://www.techyv.com/cgi-bin/qynjjjyjpjhsgj.cgi [Mon Jun 04 22:33:59 2012] [error] [client 127.0.0.1] in METHOD/PROPERTYGET "Add" at C:/Program Files/Apache Software Foundation/Apache2.2/cgi-bin/qynjjjyjpjhsgj.cgi line 1427, referer: https://www.techyv.com/cgi-bin/qynjjjyjpjhsgj.cgi
Here are the system logs:
The code:
sub calc_all_14 {
my $lib_root = catfile( $ENV{ProgramFiles}, 'Microsoft Office', qw(OFFICE12 Library Analysis) );
#print "1—$lib_rootn";
my $xll_path = catfile $lib_root, 'ANALYS32.XLL'; #print "2—$xll_pathn";
my $xla_path = catfile $lib_root, 'ATPVBAEN.XLAM'; #print "3—$xla_pathn";
my $excel = get_excel();
#$excel->{Visible} = 1;
#sleep(5);
my $book = $excel->Workbooks->Open($JSGCB_13); $book->RunAutoMacros(1);
my $sheet = $book->Worksheets(1);
# count the data line num
my $flag_counter = -1;
my $row = 5;
# for calc the line num
while ($flag_counter ne '0') {
$flag_counter = 0;
# check column 1 for the existing line
if (defined $sheet->Cells($row,1)->{'Value'}) { $flag_counter ++;
} else {
last;
$row ++;
my $row_num = $row – 1;
my $str_1_1 = '$AQ$5:$AQ$'.$row_num;
my $str_1_2 = '$AU$5:$AV$'.$row_num;
my $str_2_1 = '$AQ$5:$AQ$'.$row_num;
my $str_2_2 = '$AS$5:$AT$'.$row_num;
my $str_3_1 = '$AQ$5:$AQ$'.$row_num;
my $str_3_2 = '$AR$5:$AS$'.$row_num;
my $atp_book = $excel->Workbooks->Open( $xla_path ); $atp_book->RunAutoMacros(1);
#sleep(5);
# Application.Run "ATPVBAEN.XLA!Regress", ActiveSheet.Range(Cells(2, 2), Cells(i, 2)), ActiveSheet.Range(Cells(2, 3), Cells(i, j)), False, False, , ActiveSheet.Range("$H$26"), False, False, False, False, , False
# for C-L
$excel->Run(qq{ATPVBAEN.XLAM!Regress},
$sheet->Range($str_1_1),
$sheet->Range($str_1_2),
0,0,95,'C-L',1,1,1,1,1,1);
# for H-M
$sheet->Range($str_2_1),
$sheet->Range($str_2_2),
0,0,95,'H-M',1,1,1,1,1,1);
# for T-M
$sheet->Range($str_3_1),
$sheet->Range($str_3_2),
0,0,95,'T-M',1,1,1,1,1,1);
$excel->{DisplayAlerts} = 0;
if (-e $JSGCB_14) {
unlink $JSGCB_14;
#sleep(5);
# save and exit
$book->SaveAs($JSGCB_14);
$book->close;
undef $book;
undef $excel;
#system ('cmd');
#exec 'cmd';
Can anyone help me solve this issue? I really need help here guys. Thank you!
