MS-Excel file cant repair error
Hello experts,
MS excel file is not open it shows an error, file cant repairable and data is damage.
How to recover that data because it is very important to me.
Hello experts,
Hello James,
Is it just one file that is bringing the error or the whole Ms Excel package, because it could be just one file that is having the issues because it could be corrupt or the extension that you used to save is not supported my MS Excel. But if the whole MS Excel is having issues, you will need to troubleshoot as follows:
After you have done the above, try executing MS Excel and see if it works well.
Carl
Hi James,
Have you tried to open your excel file on another excel version? This error happens when you open a workbook in Excel 2003. It occurs even though you have opened the workbook without problems on the previous version of Excel. The workbook you are trying to open may still work on the previous version even if it is damaged or corrupted. To fix this, you need to have two copies of Excel on the same computer and then copy and paste your data from your workbook to the previous version of Excel to a new workbook in Excel 2003.
Hope it will work…
