Ms Exchange 2010 – Sp2 Upgrade error
I have just upgraded MS exchange 2010 to ps2 however I receive the error message which you can see at below:
I run the prepare AD however the error message is similar. I need your help please
Thank you
Summary: 6 item(s). 2 succeeded, 4 failed.
Elapsed time: 00:01:00
Configuring Prerequisites
CompletedElapsed Time: 00:00:01
Organization Prerequisites
Failed
Error:
Setup encountered a problem while validating the state of Active Directory: Exchange organization-level objects have not been created, and setup cannot create them because the local computer is not in the same domain and site as the schema master.
Run setup with the /prepareAD parameter on a computer in the domain acesleiria and site SEDE, and wait for replication to complete.
Elapsed Time: 00:00:18
Languages Prerequisites
Completed
Elapsed Time: 00:00:04
Hub Transport Role Prerequisites
Failed
Error:
Setup encountered a problem while validating the state of Active Directory: Exchange organization-level objects have not been created, and setup cannot create them because the local computer is not in the same domain and site as the schema master. Run setup with the /prepareAD parameter on a computer in the domain acesleiria and site SEDE, and wait for replication to complete.
Elapsed Time: 00:00:13
Client Access Role Prerequisites
Failed
Error:
Error:
The 'IIS 6 WMI Compatibility' component is required. Install the component via Server Manager.
https://technet.microsoft.com/en-us/library/.
Elapsed Time: 00:00:11
Mailbox Role Prerequisites
Failed
Error:
