David White
Posted on - 12/10/2011
I bought a very good dot.net application known as MS Expression from Microsoft.
This will assist me when illustrating the profile trace abilities of speed trace dot.net.
Early last week I installed a program that just deleted the application.
I have no idea how but it messed it and 24 hours ago when I attempted to open expression design I got this error message.
Microsoft Windows
Microsoft Expression Design has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
MS Expression from Microsoft fails to run
Well, the application that you installed may have had a tragic impact of the .net application registry entries, and thus you will need to do the following as the workaround to the issue;
Reinstall the .net application.
In case you do not want to do the reinstallation just yet, then I will suggest that you use system restore, though it will mean that the program you installed will be removed.
Click on start on your computer and open system restore from the programs.
In the system restore window, choose a time before you installed the application that caused problems.
Run system restore.
After system restore has finished, try executing the .net application and see if it works properly now.
Regards
Thompson Locker
