MS graph is not found
 I have to create a graph. In word document I find charts but not graph with datasheet. Please help me.
you want to create graph along with spread sheet, so that you can insert values through sheet. Go to tab insert and click on object. You find object under section text. Drop down object and click on object.
A window appears. Click on Microsoft Graph chart. You can also set an icon.Do mark checkbox named as display as icon. Then instead of graph icon will place at your document. Then after clicking on icon the graph appears with a spread sheet. On the graph default values display. You can edit values by clicking tab key to move from cell to cell. Enter data as per your requirement. You can change type orientation of data to display by row or column and format text which is highlighted by using Microsoft graph toolbar.
Hi
You are facing the problem that you are finding the graph in word document but it is not finding so you need to do something one thing is that:
Go to the ALT button press that button above the task bar will highlight go into the edit and find there will a tab of name containing graph go to that bar and select that bar a lots of graph will appear and select the graph of your choice select your own graph it will appear in front of you and then work on it. It will solve your problem and then add data entries into the graph and then the original graph will plot the graph you want and this will solve your problem.
