MS Identity Integration service specific error
How do I fix the service-specific error 2149781504 (0x80231000)? I got this when the Microsoft Identitiy Integration service terminated and I'm not really sure how to fix this.
Hi there,
This is a well-documented problem regarding Microsoft Identity Integration Server on VM Box. There are various solution to the problem, some are simple takes around 1-5 minutes while some other are more complex in nature and may take 30 minutes to an hour at most.
What I recommend is the following
Start the service under a wrong account, stop the service, change the account, start the service again, if it doesn’t start, abandon the keyset and restart the service again.
I hope I answered your question, since this particular problem has been plaguing the Microsoft Identity Integration Server on VM Box for quite some time now.
