MS Office 2007 Specialist Obtaining Full Edition
I have set up a free edition of MS Office 2007 Specialist. Can I be able to change it into a full edition by applying a product key or should Igo for the new set up? Kindly send me some suggestions.
You can update your program if you are downloading it from the network and you are purchasing it online in this condition you will be able to update your program and it will be available with all features. Although if you are using a DVD/CD to install your software then you need to first format your current program and then you can install your program. This is the best way to solve your problem because all the files will remain the same and there will be no change also you can choose the programs in office that you want to install like work, power point etc. You can install a fresh copy and then when you will implement it by product key then you will be able to update it also on regular basis.
If you are installing office 2007 and you have currently installed version of office 2003 then you can install the updated version over the previous version and it will work fine.
