MS Office 2010 Hebrew support fonts for free
Hello Friends,
I need few MS Office 2010 Hebrew support fonts for free. Please help me to find these fonts from the internet, by sending me the free trustable download link.
Thanks, Marie
Hello Friends,
Thanks, Marie
Hi Marie,
It would make your life easier if you purchase fonts online just click if you like this option.
On the other way around, you will need to install the Hebrew language pack then see to it that your Windows OS is enabled. Open this URL:.
Another option, Usually Windows 7 has support for Hebrew. Try to follow these steps:
1. Open the word then insert tab: Symbolsgroup: Symbol: Symbols tab
2. Let say in the font drop down, select Arial or Verdana.
3. Choose Hebrew in the subset dropdown. It is common sense that If Hebrew is not in the option. That means It doesn't support Hebrew font.
4. Then, select the character you want to insert.
Hope this will guide you with your MS Office tasks.
Steele Ney
Notifications
