damon healy
30 points
Posted on - 05/22/2012
Hello!
An MS Outlook error appeared on the screen of my computer. This error is bugging me for a long time. Is there any way that I can do to resolve this issue or is there any application that can be purchased to address this issue?
Please provide me the most effective resolution to this issue. In case that I really need to purchase something to solve this problem, what would be the best software or application should I use for this?
This is the error keeps on appearing on the screen:
Error:
Microsoft Office Outlook
The operation failed. An object could not be found.
MS Office Outlook Error: Best software to address this?
I found the solution that works for me, and the solution is to create a new profile to outlook mail set up. If you don’t know how to do this follow these steps.
Click Start, then control panel, then click mail, if you can’t see my mail, try to change the settings at the top right of the screen where you can see “view by”, select small icons. a small window will pop up, click button “show profiles”, another window will show then click add button, then enter your new profile name, Wizard will show then choose for the options, choose type of sever which your email works with then complete all the information needed then click finish.
