MS Office possible to translate in German?
Is it probable to alter the dialect in MS Office (in the individual program), for instance defaulting English language in MS Word, and German in MS Excel?
Anybody please recommend some help on this?
Ok,
There are few ways to solve this problem, don’t worry about this problem, it’s possible to fix. These steps will be helpful to fix it. First open Ms Word then select the review tab, click that tab and you will see proofing group, select language option in right side of proofing group then click it. Language window will be open, after select particular language (English) as you wish. In the excel language setting is different, because there is now a tab in converting default languages in excel (in excel 2007 package).
Click start button to select all programs, select micro soft office then go micro soft office tools, click language settings. You will see Ms Office language setting window. In this moment you can select German language in the  MS excel. I produce a screen shot for probably to find your answer at little moment.
Dear,
Yes it's possible to translate MS office in German language. In office 2007 you first open MS word and click Review tab, then you will see the Proofing group, select Set Language. When Language dialog box open then select English as default.
In Excel 2007 translate Language in German, click Start button — Microsoft office — Office tools — Microsoft office 2007 Language settings. Then select language and click Ok.
Thank You.
