Good day! While I was trying to launch my Microsoft Outlook an error message was displayed on the screen, it says:
"Recently an installed program possibly will cause Microsoft Office or some other e-mail-enabled programs to task indecently. Outlook is able to resolution this disagreement without upsetting the program that initially caused the trouble. Do you need Outlook to resolve this trouble?"
What is this for? And what does it mean? Thanks in advance.
MS Office problem due to a recently Installed Program
Dear,
Good day. You have problems in Microsoft outlook. Problem is recently installed program. Here are some solutions for you. Please follow the instruction-
If you installed any kind of software, then uninstall it and then try to use Microsoft outlook.
**If you did not install any kind of software, then it may be affected by unknown virus file.
** Use an antivirus to scan your computer and clean the virus.
** Then try again to use Microsoft outlook.
** If still problem remains, then uninstall Microsoft office.
** Delete all directory files of office if found in program files.
** Restart you computer.
** Now again install Microsoft office.
I hope your problem will be solved.
Thank you.
