When I am trying to install MS Office Professional Plus 2010, I am getting an error message which says ‘MS Office Pro + 2010 encountered and error during setup’.
It was using by me and when some errors were coming I have planned to reinstall. But when I reinstall the same, the problem starts.
I will be thankful for your help to get out of this problem.
Javion14
MS Office Professional Plus 2010 installation problem
Unregister and also re-register the Windows xp Installation technicianÂ
Click Begin > Just about almost most Programs > Components > Operate ,kind MSIEXEC /UNREGISTER, then click OK. Even if you do that correctly, that may possibly appear to be absolutely practically nothing at all happens.Â
Click Begin > Just about almost most Programs > Add-ons > Run , kindMSIEXEC /REGSERVER, and then click OK. Although you may try this appropriately, it may possibly look like almost next to very little takes place, or you might briefly see a good hot.Â
After you work this kind of command, the procedure is complete.Â
See if the above mentioned staircase assist if not uninstall business establishment 2007 following staircase pointed out below.Â
Uninstall Shine 2007 totally by working the particular resolve that instrument talked about in the Kb article:Â
Or even by using the stairway talked about with inside the KB article:Â
Then install Business establishment 2010 with all the installation media and also check if it functions.
ONG_Mass
This sounds similar to a problem i also had, but with adobe. Ok, first, go to Control Panel > Systems and Security. When you get there, you'll see something that says windows update, or something similar, depending on your OS.
Click on that and then click on "Check For Updates".
This is what I had to do. And then after words, once it is updated, Go back and try to reinstall it. If it does NOT work, uninstall it and then install it again. If it STILL does not work.
Then try this process again, but a little differently. First, Uninstall the MS Office, then update windows, and THEN, try to install it. 🙂 Sometimes software can be a pain, but their's always a way around it . 🙂
Hope This Helps!
