MS Powerpoint to PDF convert is it possible
I have so many MS PowerPoint file. But now i need to make it PDF for upload my web site.
Can I convert MS PowerPoint to PDF?
It's really need for me to do.
Hi Lynn,
It is actually possible to convert your PowerPoint presentations (PPT) to PDF by several different ways. Below are some of them:
1. Online using Zamzar check here
Throw Zamzar you can convert your documents to different types including PDF. The steps are very simple you simply browse for your file in step 1 then select PDF from convert files to menu in step 2 then enter your email address in step 3 to receive the converted files then simply press convert and that's it.
2. Offline: Using Moyea PPT to PDF converter
You can download it here
Using the program is also simple where you click ADD to add your PPT files and then select you destination folder then pressing convert.
Hope this helps.
Dear Questioner,
Of course you can convert you MS PowerPoint file to a PDF file and to do this is not at all a hard job.
You can do it easily by using some conversion utility or software easily arrange from net.
One choice can be "LEADTOOLS ePrint". By this flexible and speedy utility you can convert multiple PowerPoint slides and files into your required PDF format form your Microsoft PowerPoint application and can automatically mail it someone according to your need.
Another choice is : PowerPoint/PPT to PDF Converter. This simple and easy program can convert PowerPoint presentation with images to a PDF format. But lack of image resolution adjustments makes it hard to make a e-mail friendly PDF.
Some other solution can be: Nova PDF or Nitro PDF Professional.
