MS PPT 2007 app on maemo
I have a nokia phone N900 with Maemo. I have downloaded an PPT that was made in MS powerpoint 2007, but I can't open it. Can you provide me with a few apps?
You can use many apps but I recommend FreOffice to you.
You can use FreOffice Applications for Maemo, as it supports text, Excel, and presentations files in ODF, DOC, PPT, and XLS.
It has many advantages, such as the ability to send open office documents from your e-mail and open multiple files at once.
http://www.mobiledownloadblog.com/2010/01/download-freoffice-maemo-application.html
Good Luck.
You are having Nokia N900 and Maemo. Not only to view ppt, you can also view total MS package documents through Dataviz.
Features:
· It helps to create, view and edit all kinds of MS documents(word, excel, ppt, email attachments etc.)
· It provides you several levels to zoom.
· It supports hyperlinks.
· It saves the formatting style of the original file. So that you can get it whenever you need.
· Finally, it provides password protection for all your documents.
Regards.
