ammynadal
20 points
Posted on - 07/29/2011
I am having trouble with the menu's Home button link. Again, when I submit this to web page preview, the Home buttons work great. But when published on the web, clicking on the home button brings up an error message. Any ideas what went wrong?
Thanks,
qurat
MS Publisher ?? home button link
You can change the look of the hyperlink and you can also change the destination where it goes, when a hyperlink does not works you can investigate what the problem is and then change the address of the hyperlink accordingly.
To change the text or the order of the hyperlinks or the on the navigation bar, and then click the Navigation Bar Properties and then click on Format menu.
To fix it do the following steps
Right Click the HYPERLINK and then click EDIT.
On the EDIT HYPERLINK dialog box click PLACE IN THIS DOCUMENT and then click on the page or the Book mark that you want to link, if the Book mark has been deleted click on CANCEL go to the page that you want to link to, and then insert a Book mark and then return to the Hyperlink that you want to fix, and edit that Hyperlink.
