Ms publisher multiple choice questions and multiple answers
Hi Guys,
I am a teacher and I am new to this techyv world. I am developing a series of questions with ms publisher multiple choice questions. Now my query is that can I want to make 2 or more of the choices as the correct answer. Now, can I do this using ms publisher? And how will I be able to do this?
Answered By 0 points N/A #142041
Hi Aubrielillian,
As you told that you are teacher I have best solution to make multiple choices. You have to use Teaching Templates 2.3.0 instead of MS Publisher. This software is free having number of solutions for teachers and very easy to use you are able to do your work in less than half time.
With this software you can perform multiple task in less time for example make quiz or test having multiple choices, Gap text which is based on close test procedure, web based exercises, energy saver fill the missing letters and many more.
Just click the menu click the template which you want after selecting your background color and font create the test by filling the fields and than save it.
Than click on view quiz button your test form is in front of you with in a second.
