MS SQL cannot connect to server
All of a sudden I cannot connect anymore to the server, never had this kind of problem, did some research and read that it has something to do with the tcp/ip protocol but  it is already enabled. any other things that I need to configure?
Connect to Server
Cannot connect to (local)
Additional Information:
A network-related or instance-specific error occurred while establishing a connection to SQL Server.
The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured
to allow remote connections. (provider: Named Pipes Provider, error: 40-
Could not open a connection to SQL Server) (Microsoft SQL Server, Error: 2)
