MS SQL Query to generate calendar
Hi Techyv Friends,
I need a sample coding in MS SQL Query to generate calendar, that will help me to understand the coding.
Thanks in Advance,
Abelina Sophia
Hi Techyv Friends,
Thanks in Advance,
Abelina Sophia
The below is the sample code to generate calendar for the base month and year you input:
DECLARE @Base_Month AS INT = 1 –Setting the base month the MONTH for which you want to generate the Calendar.
DECLARE @Base_Year AS INT = 2014 –Setting the base year.
DECLARE @IntialDate AS DATETIME = CONVERT(VARCHAR,@Base_Year) + RIGHT('0' + CONVERT(VARCHAR,@Base_Month),2) + '01'
DECLARE @FinalEndDate AS DATETIME = DATEADD(DAY,-1,DATEADD(MONTH,1,@InitialDate));
SELECT
SUM(CASE WHEN DATEPART(DW, DATEADD(DD,number,@InitialDate)) = 1
THEN DATEPART(DAY, DATEADD(DD,NUMBER,@InitialDate)) END) AS Sunday
,SUM(CASE WHEN DATEPART(DW, DATEADD(DD,number,@InitialDate)) = 2
THEN DATEPART(DAY, DATEADD(DD,NUMBER,@InitialDate)) END) AS Monday
,SUM(CASE WHEN DATEPART(DW, DATEADD(DD,number,@InitialDate)) = 3
THEN DATEPART(DAY, DATEADD(DD,NUMBER,@InitialDate)) END) AS Tuesday
,SUM(CASE WHEN DATEPART(DW, DATEADD(DD,number,@InitialDate)) = 4
THEN DATEPART(DAY, DATEADD(DD,NUMBER,@InitialDate)) END) AS Wednesday
,SUM(CASE WHEN DATEPART(DW, DATEADD(DD,number,@InitialDate)) = 5
THEN DATEPART(DAY, DATEADD(DD,NUMBER,@InitialDate)) END) AS Thursday
,SUM(CASE WHEN DATEPART(DW, DATEADD(DD,number,@InitialDate)) = 6
THEN DATEPART(DAY, DATEADD(DD,NUMBER,@InitialDate)) END) AS Friday
,SUM(CASE WHEN DATEPART(DW, DATEADD(DD,number,@InitialDate)) = 7
THEN DATEPART(DAY, DATEADD(DD,NUMBER,@InitialDate)) END) AS Saturday
FROM master.dbo.spt_values m
WHERE DATEADD(DD,number,@InitialDate) BETWEEN @InitialDate
AND DATEADD(DAY,-1,DATEADD(MONTH,1,@InitialDate))
AND v.type = 'P'
GROUP BY DATEPART(WEEK, DATEADD(DD,number,@InitialDate))
