Ms Windows error code number in the error code box
Hello all,
If a program conks out, you normally found a view of a window open with some error message, along with a code number. Place the message and the number in your favorite Web search engine for a link to need an explanation, which may include a solution. This attempt causes more loss than hit, unfortunately. Gregory Braun's free Error Messages for Windows utility lists Windows error messages using their code numbers, but it's unable to help you find the source of the error. Hope I can get an advice from here. Thanks in advance.
Error:
Lookup
Specify an MS Windows error code number in the Error Code box.
The error code you enter will be described in the text window below.
Error Code 32
Description: The process cannot access the
because it is being used by another
process.
